FoMoCo hírek
Két új crate engine
Ford 427 FE
Ford X302
Ford 427 FE
Ford Racing Announces the Return of the 427!
Part Number: M-6007-Z427FFT (front sump pan), M-6007-Z427FRT (rear sump pan)
Part Description: The company that created the 427 FE engine line announces a modern version of the legendary motor. Built on Ford Racing's new BOSS 351 block, the 427 crate engine is engineered and built for drive ability and durability while still offering a throaty growl.
The 427 crate engine is ideal for street rods, kit cars and all Ford projects requiring big power in a reliable small block package.
Specs:
427 cubic inches (4.125" bore x 4.00" stroke), 9.5 deck 351 BOSS block with 4-bolt mains
535 hp @ 5600 / 545 lb.ft. torque @ 4500
10.5:1 compression ratio
Neutral balance forged steel crank, steel H-beam connecting rods and forged pistons
Aluminum Ford Racing Z cylinder heads with 2.02 intake and 1.60 exhaust valves w/ 63 CC chambers
Hydraulic Roller Camshaft
Includes water pump and harmonic balancer
Distributor, Ignition Wires, Intake, Fuel System, Exhaust and Flywheel are needed to run
Standard 12/12 FRPP Crate Engine Warranty
$8,8000.00 MSRP
Other Ford Racing Related Items:
Valve Covers: M-6582-W427 (black), M-6582-W427B (blue), M-6582-W427P (polished), Add the 427 FE look to any SB Ford.
Flywheel: M-6375-D302B, Make sure to use the correct flywheel for a balanced assembly!
Water pumps: M-8501-G351 or M-8501-C50, Pick the right pump for your accessory drive!
Intakes: M-9424-V351 Victor Jr. for big power, M-9424-Z351 Performer RPM for low-end torque and installed height
Short Block: M-6009-Z427, 427 short block is available for the DIY engine builder.
Contact Information:
Ford Racing Performance Parts
1-800-367-3788
http://www.fordracingparts.com" onclick="window.open(this.href);return false;
Ford X302
X Hits the Spot With New Value Packed Crate Engine!
Part Number: M-6007-X302
Part Description: Ford Racing introduces the best value in 302 crate engines, the X302. The X302 delivers forged pistons and high performance aluminum heads at a price the competition offers factory iron heads and cast pistons. Topped with a set of Ford Racing polished aluminum valve covers the X302 looks as good as it performs.
The X302 crate engine is ideal for street rods, kit cars and any Mustang project plus it's built right here in the USA!
Shown with water pump not included.
Specs:
306 cubic inches (4.030" bore x 3.00" stroke), seasoned 302 block
340 hp / 310 lb.ft. torque
9.0:1 compression ratio
Cast iron crank, I-beam connecting rods and forged pistons
Aluminum Ford Racing X-306 cylinder heads with 1.94 intake and 1.54 exhaust valves w/ 64 CC chambers
Hydraulic Roller E303 Camshaft
Includes 50oz. harmonic balancer
Ford Racing die-cast polished aluminum valve covers
Distributor, ignition wires, intake, fuel system, water pump, exhaust and flywheel are needed to run
$3,495.00 MSRP
Other Ford Racing related items:
Valve Covers: M-6582-LE302C (polished), M-6582-LR302BL (blue) Customize your look with our broad selection of valve covers!
Flywheel/Flexplate: M-6357-B302 (T5), M-6375-A50 (AOD), Make sure to use the correct flywheel for a balanced assembly!
Water pumps: M-8501-C50, M-8501-G351, Pick the right pump for your accessory drive!
Intakes: M-9424-E302C Performer RPM for low-end torque
Z427 Crate Engine: M-6007-Z427FFT/FRT - Need more power and torque? Check out our Z427!
1-800-367-3788
Phantom Shopping
- Kabóca
- Csatlakozott: 2010.02.03 16:39
Próbavásárlás minden Fordos számára
Hasonló hozzászólást többet nem kérünk!
Köszi,
ui: Szireta, nagy duzzogva töröltem a hozzászólásod, mert itt nincs helye magának az elõzõnek sem, de természetesen a megfelelõ helyen szívesen látjuk építõ kritikádat
- szireta68
- Csatlakozott: 2008.09.07 21:06
Re: Próbavásárlás minden Fordos számára
próbáltam viccesen lerendezni a dolgot, szerintem jó észrevétel volt, hátha tudnak egy jó amerikai-FORD szervízt a srácok Pesten!!!Phantom Shopping írta:A hozzászólás ide átrakva
Köszi,
ui: Szireta, nagy duzzogva töröltem a hozzászólásod, mert itt nincs helye magának az előzőnek sem, de természetesen a megfelelő helyen szívesen látjuk építő kritikádat
..., de hogy ezek után az én hozzászólásomat törölted és nem az övékét, lássuk be nem volt szép Tőled.
Szuper jól indul a 2011-es Mustang év
Míg a ráncfelvarrás nem hozott új lendületet, sőt a 2010es év kimondottan méjy pont volt a Mustang eladásokban, az új, 2011es motorok meghozták a várt eredményt. Idén eddig 3szor annyi Mustang-ot rendeltek a vásárlók mint tavaly. A megrendelt kocsik 50 %-a V6-os, 41 % GT és a maradék 9 % GT500-as. Az előző években a V6-os dominálta az eladásokat, szal az is jó most, hogy több drágább modellt vesznek a vásárlók.
Ford már 2 millió Sync rendszerrel szerelt autót adott el
A Microsoft Sync rendszerrel könnyedén lehet különböző multimédiás eszközöket (telefon, iPod, stb) a beépített monitorhoz6erősítőhöz csatlakoztatni. Ford felmérése szerint sok potenciális vásárlónak érv egy Ford, Lincol vagy Mercury vásárlása mellett ez a rendszer és az autótulajdonosok több mint 80 %-a elégedett vele és ajánlaná ismerőseinek is.
A Mercury vásárlói voltak a legelégedettebbek 2009-ben
A J.D. Power 2009-es felméréséből kiderült, hogy a középkategóriás autók között a Mercury vásárlói voltak a legelégedettebbek 2009-ben.
A felmérésből az is kiderült, hogy a gazdasági válság jó hatással volt a kereskedői magatartásra is, mert nagyban múlik rajtuk az autóeladás. 5ből egy vásárló hagyta ott a kereskedést, ha nem megfelelő bánásmódot vagy más "kereskedői játékot" tapasztaltak.
Dízel Mustang?
Mustang sokat javult a ráncfelvarrásban, már az európai elvárásokat is teljesítheti. Viszont a kicsi V6os motor is igen nagy errefelé. Ezért a neten felröppent az a hír, hogy készíthetnek turbodízeles verziót is.
Fordnak a aPSAval közösen van egy jó kis 3 l-es V6os dízele, amely a Jaguárban 270 LE-t és 600 Nm-t teljesít. Idegenül hangzik, de biztos rendesen menne vele a Mustang. Csak szvsz nagyon drága lenne egy ilyen motorral.
Fél óra az semmi... ha nem kell máshova menned és van hova tenni, szerintem abszolút jó.... ha nekem igy lehetne szó nélkül cangáznék
